RCU Forums - View Single Post - Engine break in
Old 06-04-2007 | 07:45 PM
Sean Bowf's Avatar
Sean Bowf
Default RE: Engine break in
Nitroburn1, I think if you ask 10 different people how to break in a boat engine, you will get 10 different answers....BUT, I pretty much do what you did with the Vegas.
I start at about 3 turns out on the high speed needle. For the first tank, I take a couple laps, then let it cool, then take a couple laps, then let it cool, then run the rest of the tank out. I leave the needle where it is for the 2nd tank...then starting on the third tank I start to lean it up an eigth of a turn per tank until it runs right. At about 7 tanks, your boat should be running pretty good.
Sean
