RCU Forums - View Single Post - Formula to calculate CG movement
Old 06-05-2007 | 10:04 AM
budpro's Avatar
budpro
Default RE: Formula to calculate CG movement
Exeter,
I'm in a similar process designing floats for an older
trainer..and locating the CG and the balancing act thing.
I ran across this site: http://www.rrcc.org/downloads.htm
Down the page is a program by Mike Sayer,
called Model Aircraft Weight and Balance
And then I found this one which has helped me
the most, because it is simple: http://www.seniorpattern.com/pdf/BalancingAct.pdf
Hope this helps you.
Good luck, fly high be safe, later, bud
