Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Formula to calculate CG movement >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 06-01-2007 | 07:26 AM
exeter_acres's Avatar
Default Formula to calculate CG movement
Help...
I remember there is a formula out there to help calculate how far the CG moves based on how you move a weighted object in the airframe....
ie: you move a battery that weighs 4 oz, 3 inches rearward, what is the new CG.....
I remember seeing a formula to calculate this all out....
it is NOT the standard "Calculate the CG" formula that is all over the place, this one actually dealt with moving objects in the airframe
Anyone know where I can find this?
Exeter
Old 06-04-2007 | 09:37 AM
Default RE: Formula to calculate CG movement
I think this will work
CG shift = (weight of object moved) * (distance moved) / (total weight)
In your example assuming a 3 lb airplane
4oz * 3in / 48oz = .25in
Old 06-05-2007 | 10:04 AM
budpro's Avatar
Exeter,
I'm in a similar process designing floats for an older
trainer..and locating the CG and the balancing act thing.
I ran across this site: http://www.rrcc.org/downloads.htm
Down the page is a program by Mike Sayer,
called Model Aircraft Weight and Balance
And then I found this one which has helped me
the most, because it is simple: http://www.seniorpattern.com/pdf/BalancingAct.pdf
Hope this helps you.
Good luck, fly high be safe, later, bud
Old 06-05-2007 | 11:36 AM
thanks gents... appreciate it!
