RE: Precision Aerobatics Katana MD Build and Fly
Airboss 35A ESC has an on-off switch so I needed to find a place to put it. the switch has a 2mm thread, so I found two short 2mm screws, cut a light piece of balsa with openings to the switch and for two holes.Then glued in place and cut the covering film fitted in place and set the screws.
