RE: Precision Aerobatics Katana MD Build and Fly
sweet!
That makes disarming the plane at the end of a flight so much safer... If anything bumps my sticks while i am disconnecting there could be serious trouble! You can make the system safe at a flick of a switch then turn your tx right off before disconnecting the pack.
I have to carefully place the tx flat on the ground, stay clear of the prop's general area, hold hte plane at all times in case it glitches into action, remove canopy and disconnect pack withotut ever letting go of the plane in case it goes WOT on me unexpectedly.
I saw a guy who needed like 20 stitches after his foamy with a small power system jumped up and bit him hard in the arm. I am willing to bet the KMD's power system is enough to take fingers clean off...
You can never be too carefull with these things, so easy to prevent, so hard to reverse!
