RCU Forums - View Single Post - Best pushrod termination setup?
Old 06-05-2007 | 09:20 PM
flipstart
Default RE: Best pushrod termination setup?
Yes, the O.D. of the rod is too small to give you adequate thread depth. Also in my post, actually it is better to use one threaded end and solder a clevis on other end so only one end is adjustable. If you are using the swivel connectors, then cut rod to correct length, solder on a threaded connector and use swivel connector on each end.
