RCU Forums - View Single Post - Choke really needed?
Old 06-06-2007 | 12:08 PM
RJConnet
Default RE: Choke really needed?
ORIGINAL: killerG
I just got my first gas motor, a Brillelli 46. The choke arm is going to hit the cowl and I don't really want to cut a hole in the cowl. I am not using a choke servo. so can I remove the choke?
I had the same situation so I simply cut off the lever arm and JB Welded the head of a 8-32 or 10-32 socket head cap-screw to the choke axle (whatever you want to call it). Now I operate the choke with a ball end hex-driver through a small hole in the cowl.
[8D][8D]........RJ
Meant to attach this photo but didn't suceed on the first try
