RCU Forums - View Single Post - Venture 60 - First build
Old 06-06-2007 | 07:19 PM
  #55
Kmot's Avatar
Kmot
My Feedback: (24)
Default RE: Venture 60 - First build
The wing centerline should be parallel with the table top. Your fuel tank should be empty also.
Once you get it balanced upside down, just do a quick double check with it right side up. In both cases, you want the nose of the plane to be slightly heavy as opposed to the tail of the plane. Level is perfect.
Differential Aileron Throw
