RCU Forums - View Single Post - pull start engine, starterbox & no pull start
Old 06-06-2007 | 11:41 PM
mozzzy_2000's Avatar
mozzzy_2000
Default RE: pull start engine, starterbox & no pull start
my Q? is can i use a pullstart engine with the crank shaft sticking out the back on a starterbox. i conserned about air leaks and stuff.
Put the backplate assembly back on regardless of whether the pullstart works and just pop on a starterbox. Should be sweet. By the way you should be able to get a 12V gell cell from your LHS.
