IE6 and XP
It also affects the LINK button function.
When I select some text ( I have to use the SHIFT-ARROW keys to select because click-drag-mouse doesn't work) and want to create a link with that text, the LINK button used to bring up a prompt with the highlighted text prefilled in at the URL text textbox. It doesn't do that now. You have to manually fill in the URL text again no matter if you have anything highlighted
EX: [link=http://www.rcuniverse.com/forum/post.asp?do=reply&messageID=5954239&toStyle=tm]LINK TO THIS THREAD[/link]LINK TO THIS THREAD
[link]http://www.rcuniverse.com/forum/post.asp?do=reply&messageID=5954239&toStyle=tm[/link]LINK TO THIS THREAD
As you can see, the link prompt simply pushes the selected text aside and creates the text again (first Example). If you leave the URL text blank ... it simply inserts the URL and again pushes the highlighted text aside.
I copied the Error on Page text (found by clicking on the Warning prompt on the status IE status bar). It only occurs during the post.asp EDIT ( It also happens at the EDIT.asp). I can highlight text all day as long as I'm not at post.asp.
Here's the text:
LINE: 18
CHAR: 2
ERROR: Object doesn't support this property or method
CODE:0
URL:
http://www.rcuniverse.com/forum/post...239&toStyle=tm
The URL is the URL displayed while writing the post.
