Engine mount for GMS .76
Can anyone tell me what mount I should use? Mounting it on a H9 Hellcat. I'd ideally want something with vibration reduction built in. I was looking at the
Dubro Motor Mount .75-1.08 2-Stroke. Would that work?
Mounting Specs:
Center distance width across mounting holes: 2.0" (52mm)
Center distance length of mounting holes on same side: 1" (25.4mm)
Length from front of crankcase to backplate screws: 4.0" (103mm)
Width across mounting flanges: 2.4" (61mm)
Total height of engine: 3.8" (101mm)
Length from center of head to front of crankcase: 2.9" (73.5mm)
Widest width of crankcase neglecting mounting flanges: 1.7" (43mm)
Length from front of crankcase to center distance of front
mounting hole: 2.4" (61mm)
Height from crankshaft center to top of head: 3.1" (79.5mm)
Crankshaft thread size: 5/16-24
