 Engine mount for GMS .76 >
Old 06-08-2007 | 01:46 PM
Vendetta's Avatar
Default Engine mount for GMS .76
Can anyone tell me what mount I should use? Mounting it on a H9 Hellcat. I'd ideally want something with vibration reduction built in. I was looking at the
Dubro Motor Mount .75-1.08 2-Stroke. Would that work?
Mounting Specs:
Center distance width across mounting holes: 2.0" (52mm)
Center distance length of mounting holes on same side: 1" (25.4mm)
Length from front of crankcase to backplate screws: 4.0" (103mm)
Width across mounting flanges: 2.4" (61mm)
Total height of engine: 3.8" (101mm)
Length from center of head to front of crankcase: 2.9" (73.5mm)
Widest width of crankcase neglecting mounting flanges: 1.7" (43mm)
Length from front of crankcase to center distance of front
mounting hole: 2.4" (61mm)
Height from crankshaft center to top of head: 3.1" (79.5mm)
Crankshaft thread size: 5/16-24
Old 06-08-2007 | 01:52 PM
Vendetta's Avatar
Default RE: Engine mount for GMS .76
BTW what towwer recommends is the Great Planes Adjustable Engine Mount .60-1.20.
Old 06-08-2007 | 02:36 PM
carrellh's Avatar
If you want a vibration reduction mount, Dubro has several.
http://www2.towerhobbies.com/cgi-bin...SM&C=GMH&V=DUB
I think the choice will depend on how long the mount needs to be to locate the prop drive the right distance from the firewall.
Old 06-08-2007 | 03:07 PM
Vendetta's Avatar
Yeah thats why I was asking, was wondering if anyone had already done this setup. The H9 manual says that from the front of the drive washer to the firewall it needs to be 142mm / 5 9/16". Thats why I was thinking the Dubro Motor Mount .75-1.08.
Old 06-08-2007 | 03:19 PM
carrellh's Avatar
Unless someone with experience speaks up, I'd probably go with this one:
http://www2.towerhobbies.com/cgi-bin...&I=LXD632&P=SM
The beams are 3.25 inches long and the total length is 4 inches.
If the beams are longer than you need you can always cut them off.
It's harder to make them longer.
