Felt clinks aren't recommended for turbines. I know that some have done it without issue, however it is easy for felt particles to migrate from the clunk and plug your injectors or downstream filter.
You can make a pleated filter clunk from an automotive fuel filter. The JPO website use to have a how to set of instructions on their website. For some reason they removed it. They work great and will drain the last bit of fuel from your tank without any air. I still do use a UAT with it, which I make myself using the same filter..
See
http://www.rcuniverse.com/forum/m_15...tm.htm#1527831
http://www.rcuniverse.com/forum/m_20...olution/tm.htm
Joe
