Originally posted by ASteele
The settings that the big rappy has straight out of the box will do 3D very well. You should be able to do flips and rolls along with inverted hovering.
i can't install the gyro right.
tried almost everything, even copy the specs from other 60 size helis. the tail is not stable!!!
starting slowly from low to half throttle it's a little stable,but when i open the throttle more or close it fast from full to half, the tail start spinning every time.
