Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
G2 heli files,where? >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 03-03-2003 | 12:32 AM
Default G2 heli files,where?
I'm trying to setup a raptor 60 in G2 with not good results.
is there any place to download 3D settings or a complete heli? (any 60 size)
Old 03-03-2003 | 01:05 AM
The settings that the big rappy has straight out of the box will do 3D very well. You should be able to do flips and rolls along with inverted hovering.
Old 03-03-2003 | 09:18 PM
i can't install the gyro right.
tried almost everything, even copy the specs from other 60 size helis. the tail is not stable!!!
starting slowly from low to half throttle it's a little stable,but when i open the throttle more or close it fast from full to half, the tail start spinning every time.
Old 03-05-2003 | 12:23 AM
Two things. 1st you may have to trim a little rudder. The other thing is make sure you have it in HH mode. Left forward switch must be in the middle setting. That should fix the problem.
Old 03-06-2003 | 04:12 AM
Default Raptor Downloads
Hi
What www....... website can I go to to download a Raptor 30 V2?
Please help.
Rich
