RCU Forums - View Single Post - trainer jet help
Old 06-09-2007 | 08:17 PM
Wayne22's Avatar
Wayne22
Default RE: trainer jet help
bad idea for several reasons....
-2 more litres of fuel is going to add a lot of weight to your jet which you have to pack around for the whole flight
-the extra weight will increase the wing loading, and make the plane a real slug to fly until a substantial amount of fuel is burned off.
-the extra wingloading will increase the stall speed, and may well increase the risk of a takeoff accident, or a high speed stall
-without a pump in each wing tip tank, there is no guarantee that they will empty completely, or evenly (even that is no guaranty)
-if one tank emptys more than the other, or you have one that refuses to empty, you are going to have a lot of difficulty keeping the wings in trim, and may run out of aileron control.....
10 minutes is not a bad endurance for a jet..just land, check everything over, refuel and go fly again...............
