RE: Where to add Stall strip
By letting the root stall first you will probably have a tip stall immediately after that event.Fly in with a shallow approach,avoiding sudden throttle blips,maybe keep some power until you are in ground effect,a glide at idle will be a problem.Check for lateral balance too.
Good luck with the maiden
