RCU Forums - View Single Post - Where to add Stall strip
Old 06-10-2007 | 03:25 PM
borna
Default RE: Where to add Stall strip
Ok guys thanks for all the advice. I can tell you that I learned a lot in the last 2 days about tip stall, characteristic of tapered wing, stall strip, and land with rudder.
From what I been hearing stall strip is not a good idea, so you guys convinced me not to use it since is not going to make the plane land any better. .
However what I don’t understand is then what is the benefit of stall strip if is not going to improve the stall characteristic of the plane??
I have read it that it is used in a real plane and here is a picture of the military chipmunk with stall strip.
Borna
