RE: DIFF Gear
if its the same transmission case, then its the same. it shouldn't be smaller. if it is, then it must be using a different transmission case. The cases are designed so that the holes for the gear shafts and diff outdrives fit perfectly while having the perfect gear mesh. the gear mesh isn't adjustable.
