DIFF Gear
i am buying a aluminum differential gear for my nitro evader st is there a size difference between the nitro evader bx and the st
i think there is because the bx is smaller[8D][8D][8D][8D][8D][8D][8D]
if its the same transmission case, then its the same. it shouldn't be smaller. if it is, then it must be using a different transmission case. The cases are designed so that the holes for the gear shafts and diff outdrives fit perfectly while having the perfect gear mesh. the gear mesh isn't adjustable.
