RCU Forums - View Single Post - Goldberg Extra 300
Old 06-11-2007 | 07:28 AM
  #150
Mark786's Avatar
Mark786
Default RE: Goldberg Extra 300
I just about have the plane the way I like it. I can pick it apart and find things to fix but in general it came out very nice.
If I were to pick, I would repaint the cowl and pants as I did it when it was raining and they turned out less than glossy.
I found that my motor offset was way off, I used washers and did not measure. I just lined it up to the cowl and I found that Goldberg had put the cross hairs wrong on the firewall by 3/16" so lining up the cowl gave me 8 degrees insead of the 2 degrees recommended. I have remounted the engine and it loops much better now.
I have included the most recent pictures and here is a list of parts.
CG Extra 300 kit
OS 1.20 AX
16x8 APC prop
Fiberglass specialties Cowl & Wheel pants
12 OZ dubro fuel tank
fuel dot for third fueling line
1/5 scale pilot (not installed yet)
Gold-n-rod pushrods
Dubro heavy duty control horns & ball links
Dubro fiberglass landing gear
Spektrum AR7000 receiver
JR DS821 Digital servos all around
Dual elevator servos next to pull-pull servo
Li-po battery
Angles LG forward to prevent tip-overs
AUW 10# 1oz.
ID:	701823   Click image for larger version
ID:	701824   Click image for larger version
ID:	701825   Click image for larger version
