RCU Forums - View Single Post - Hinges
Thread: Hinges
Old 06-11-2007 | 05:10 PM
Dan D
Default RE: Hinges
Hi ,
I have used these hinges before and I used Epoxy with a little vaseline on the joint where it hinges.These hinges I dont like, and I do not use them any more. The slot has to be cut wide, the gluing can be time consuming and tricky,even properly installed they leave a gap that can cause flutter when flying.
Ask around you may want to use another style hinge.
Dan
