RCU Forums - View Single Post - Ryobi 31cc carb help needed.
Old 06-11-2007 | 05:12 PM
Danh4
Default RE: Ryobi 31cc carb help needed.
Now it sounds like you're having the exact same problem I was having when I had my fuel line hooked to the wrong brass tube on the carb. Low needle worked fine, high needle didn't work at all, engine died when I tried to throttle up. Does your carb have 2 tubes?
