Ryobi 31cc carb help needed.
Old 06-11-2007 | 05:12 PM
Default RE: Ryobi 31cc carb help needed.
Now it sounds like you're having the exact same problem I was having when I had my fuel line hooked to the wrong brass tube on the carb. Low needle worked fine, high needle didn't work at all, engine died when I tried to throttle up. Does your carb have 2 tubes?
Old 06-11-2007 | 06:02 PM
My Feedback: (12)
Yes my carb does have two tubes but I am 99.9% shure I have the fuel line conneted to the correct tube. The tube closest to the engine by the adjusting needles is the primer tube which I have blocked off and the barbed conector on the other side of the carb is my fuel inlet.
Old 06-11-2007 | 06:10 PM
Both of the tubes on my carb were on the same side and I was 99.9% sure I had them hooked up right too! What model # carb are you using?
Old 06-11-2007 | 06:27 PM
My Feedback: (12)
I believe my carb is a wt-349 12.5mm bore. It has a brass tube beside the adjustment needels that I am quite shure is the primer tube and a fuel fitting on the other side of the carb with a 90 degree barbed plastic fitting that I am quite shure is the fuel fitting. I can blow air through the primer fitting and I can not blow air through the barbed fuel fitting.
Old 06-11-2007 | 07:40 PM
I found this right here on RCU, seems odd that he had several of the same carbs as yours with the same problem...
http://www.rcuniverse.com/forum/m_58...tm.htm#5818624
