RE: Ryobi 31cc carb help needed.
I believe my carb is a wt-349 12.5mm bore. It has a brass tube beside the adjustment needels that I am quite shure is the primer tube and a fuel fitting on the other side of the carb with a 90 degree barbed plastic fitting that I am quite shure is the fuel fitting. I can blow air through the primer fitting and I can not blow air through the barbed fuel fitting.
