RE: Weak Tail Rotor Response (G90, SA)
Which pinion are you running? I used the 11T for a while then stepped up to the 12T, a lot of difference with the increase in head speed between the 2. Now if you are talking piro rate adjust the limit on the gain channel for the gyro (if there is a remote gain for the G90)
Pete
