I ended up with the CG roughly 1/4 forward from the recommended spot, 3 degrees of right thrust, two degree of up thrust, I think I sanded about 1/8th inch off the back of the sing saddle.
Is this in addition to the right thrust built into the firewall? 3 washers on the left side and 2 under the bottom right? What incidence did you end up with after sanding the wing saddle?
Kendall
