RE: Venus II
My plane is nose heavy. Maybe that's why I have never had a bounce. It flies absolutely first rate this way so I never had the itch to change it.
Bob is right. When you land with the spoilerons it's like someone reaches out and holds it down on the ground. I'm also used to landing a true pattern ship which requires that you cut the throttle back to 0 out there as far as the eye can see. I tried spoilerons on that ship and they are not as successful as the Venus II
