...youd need a new esc as the aquacraft one is meant for 6 pole and feigaos are 2 pole
That makes no difference - the ESC will work on about any sensorless BL motor regardless of the number of poles. The real problem is the amp rating of the SV ESC, it is 45 amps while an XL will pull much more if you want to go faster.
