Go Back  RCU Forums > RC Boats > Speed - Electric
 Mono vs Cat >
Mono vs Cat
Speed - Electric For all your electric boating needs.
Mono vs Cat
Old 06-12-2007 | 08:21 AM
Default Mono vs Cat
I have been enjoying my supervee 27, but I am wondering if there is a way to find about the same amount of speed with more stability. Will a cat hull provide that additinal stability I am looking for? Any suggestions on a hull that I might start with that would be competitive to the Supervee 27? My brothers and I typically race in a river that is generally very calm.
Old 06-12-2007 | 08:38 AM
saleens7's Avatar
Default RE: Mono vs Cat
cat will have more stability in calm conditions....i would guess the SV system in the BJ26 would work great...
you can also try it with an 8XL and a hydra 120 esc with 12-14 nimh cells or 4s lipos...
someone on the ose forum used a nemisis blue 7XL on 2 7.4v 8000mah lipos and did 46.9mph...
http://forums.offshoreelectrics.com/...t=blackjack+26
Old 06-12-2007 | 09:06 AM
or a scat cat 26!!!!
Old 06-12-2007 | 09:12 AM
saleens7's Avatar
oh yeah...that too (go for the scat cat...its cheaper and easier to set up since the deck isnt already glued on...) with the supervee setup in that youl be doing circles around your bro's SV...
Old 06-12-2007 | 01:46 PM
I like the H2O [link=http://www.finedesignrc.com/hullsh20.asp]alley cat[/link].
Old 06-12-2007 | 04:52 PM
Orange Crush's Avatar
My 29" Mean Machine handles much rougher water than my SV and is over 10 mph faster. I do have a 6s setup in it, however. I do think that I could get 50 mph with it using a 8 or 9XL on 12 cells or 4s Lipo though.
Old 06-13-2007 | 01:48 PM
ORIGINAL: saleens7
So I should be able to drop my SV27 hardware into the Scat Cat 26 without to much hassle?
Old 06-13-2007 | 03:06 PM
saleens7's Avatar
when you say hardware, you mean just the electronics hardware or the strut and rudder as well?
if you mean strut and rudder, the rudder could be used, but the strut isnt the right type...you would need one like this
http://www.offshoreelectrics.com/pro...d=ros-21-strut
you would need a different motor mount as well
http://www.offshoreelectrics.com/pro...od=ose-drmount
make sure when you mount it that you angle it downward so its pointed to where the strut will be....you can take a peice of wood and cut the angle into to do this...
besides that, all the other stuff should be able to transfered to the scat cat...you wont need the trim tabs or the turn fins though...
Old 06-13-2007 | 04:03 PM
Or just p/u the "Race Basic" kit from Randy and have him add the correct motor mount to the package for you...
ABS Race Basic
Race Basic Kit contains: same as Hull Kit plus: a special drive system, rudder, flex shaft assembly, servo bracket, push rods and seals
Suggested Retail $259.95 Sale Price $169.00
Old 06-13-2007 | 04:30 PM
Yes, that does sound pretty good. Then I could just pull the motor and the electronics and I would be ready to go. Because I lack self control, what would be the suggestion if I were to go with a fiberglass hull?
Old 06-13-2007 | 04:54 PM
saleens7's Avatar
drifter S...(180$ hull only[X(][:@])
theres the mean machine hull, but youd probably want a better motor (like a 540XL) but then youd need a new esc as the aquacraft one is meant for 6 pole and feigaos are 2 pole
theres the proboat blackjack 26...(youd have to go to horizon hobby and buy the hull only there...but its not the best quality out there and costs much more than it should)
theres probably others out there
Old 06-13-2007 | 04:55 PM
saleens7's Avatar
the scat cat w/ hardware combo is still the best choise if you factor in cost and quality....
Old 06-13-2007 | 07:55 PM
Got RPM's Avatar
...youd need a new esc as the aquacraft one is meant for 6 pole and feigaos are 2 pole
That makes no difference - the ESC will work on about any sensorless BL motor regardless of the number of poles. The real problem is the amp rating of the SV ESC, it is 45 amps while an XL will pull much more if you want to go faster.
Old 06-13-2007 | 08:58 PM
saleens7's Avatar
im not so sure....quicksilver tried the SV esc on a 12L feigao and he couldnt get it to work...a lot of people are saying thats what the problem was...
Old 06-13-2007 | 09:27 PM
I'd say a Toysport from OFE or a Mean Machine as far as glass goes for 12 cell...or 4s Lipo. I can't tesitfy to the Toysport, although I'd love to build one up. I love the looks of the hull. I can say that I have "backed" my Meanie down to the mid 40's and can corner @ WOT all day. It's a blast and has my hands shaking every time I take off.
Old 06-13-2007 | 09:29 PM
saleens7's Avatar
yeah, but the toysport cat is 500$ (with hardware)....thats kind of alot, but they produce some of the highest quality hulls out there, so its hard to argue with the price...
Old 06-13-2007 | 09:35 PM
True...and like I said. "I've never built one up". Seems like I heard somewhere about a handling deficiency with the Toy, but that might have been in relationship to SAW... Don't let me start a rumor, though. I'm getting old...and, well, uh.... nevermind.
