UCANDO with OS .91FX Please help
How does the ballance work out with the OS 91 in place? Any benefit in using lighter servos in the tail? (HS 225 MG) Or am i likely to add lead anyway? i also have standard servos that might work if i run them on 6 V. I also have a few HS 645MG's available. Those servo leads are going to be long! sheesh! i kwew it was long, but i had no idea!
So far i like it pretty well. Should be a cakewalk to get it all together.
So far i have the engine mounted up. I opted for the engine to be side mounted. Won't look as clean as Mark's but ....
I had to redrill the firewall to rotate the engine to about the 10 o'clock position so the exhaust will clear.
