RE: Align Tires
Hey Scott long time no see.. I set my nemmi with 1 degree toe out in the front and 2-3 degrees toe in on the rear. the front camber is 3 degrees and the rear is 2 degrees. With this setup the truck tracks very straight and hard launches it does not seem to pull at all. Also, its handling has a nice balance on hard to tacky dirt and pavement, grass is a bit more responsive and loose/dusty dirt its has a slight push but thas expected with a truck this heavy!!
Hope that helps, Scott.
Dont be such a stranger
