Align Tires
Ok fellas, I was resisting this one, but now that we have this answer, "eyeball it" I just have to get in on this. there is a device called [link=http://www.hobbypeople.net/gallery/708097.asp]Monster Camber Gauge made by RPM[/link] You will do a whole lotr better if you use this for your camber and then zip tie it to a 1" x 2" straight peice of wood or rigid yard stick to get your toe in front a rear. It not high precision but works very well for me since no one makes a toe gauge big enough for these trucks. maybe just maybe now that work is not so intrusive on my fun stuff I will come up with a simple design you guys can make one from, maybe.
Hey Scott long time no see.. I set my nemmi with 1 degree toe out in the front and 2-3 degrees toe in on the rear. the front camber is 3 degrees and the rear is 2 degrees. With this setup the truck tracks very straight and hard launches it does not seem to pull at all. Also, its handling has a nice balance on hard to tacky dirt and pavement, grass is a bit more responsive and loose/dusty dirt its has a slight push but thas expected with a truck this heavy!!
Hope that helps, Scott.
Dont be such a stranger
TRD,
Thanks.
Actually that is very close to what i have now, but probably running a bit more camber at the front as I was trying to help the turn in. Mind you, changing the shock settings made it a bit darty, so I may dial some camber out.
Cheers.
Thanks.
Cheers.
My RPM toe guage works fine on my truggy, and I use the rpm camber guage too. I bolt on a set of wheels with no tires mounted so the sidewall doesn't throw the settings off. I run 3 toe in and 2 - camber in rear,1 toe out and 1.5- camber in front.
