Hello!!!!
You are right about bigger mAH will give you longer flights
You will need longer charging time if you use the same charger, you can buy a better charger like this
http://www2.towerhobbies.com/cgi-bin...&I=LXEYD4&P=ML
It can charge different mAH batteries in the same charging time
Escipion
