hi guys, could someone tell me whats the difference between the prop ( as in the drive shaft that is attached to the prop and comes out behind the boat) being behind the rudder and the difference between rudder being further out then the prop ( as in the drive shaft that is attached to the prop and comes out behind the boat) is? Hope you get what i mean, if you dont i attached somw pictures to make you see the picture better. So its a question about what are diff from the rudder being before the drive shaft(the prop that comes out of the behind of the boat) and difference of the rudder being after the drive shaft/
And also, is this a good buy? if not could you guys recommend some boats.. preferrably Fiberglass hulls, and Nitro or Elect doesnt matter!
clink on the link:
http://www.jethobby.com.sg/cgi-bin/e...5&cid=49&idx=1
http://www.jethobby.com.sg/cgi-bin/e...0&cid=49&idx=1
cheers guys.
PS: hope ypu guys dont mind me posting this thread on Electric boat section too. thanks guys
cheers..
vin
