RCU Forums - View Single Post - Masterspin 99 Controller and C50 13XL Comp Setup
Old 06-19-2007 | 05:47 PM
OhD
Default RE: Masterspin 99 Controller and C50 13XL Comp Setup
ORIGINAL: PATTERNPATTERN
Hi Guy's
Just wondering what is the diff between C50 13XL Comp, and the 14XL, or 15XL? Also what is the optimum speed controller setting and prop combintaions for each of the three motor?
Was always wondering about the difference was, hopefully someone can help.
Thanks for your help,
Different windings resulting in different Kvs meaning you need to use different props to get the optimum load. The 14 seems to be the most popular swinging the APC 22x12. The 13 wants to turn at a higher rpm so you need a smaller prop. The 15 slower so it will swing a larger prop.
Timing should be set at 0, 1, or 2 degrees. I use linear curve, soft acceleration and slow shutdown.
Hope this helps, Jim
