Masterspin 99 Controller and C50 13XL Comp Setup
My Feedback: (46)
NJ
Anyone care to share/list their settings for the Masterspin 99 and C50 13XL Comp?
I am particularly interested in the setting for Acceleration. Default is 1S. The higher the setting the softer from what I was told. I experimented on the ground with 2S. Seemed OK, but I just don't have the experience to really know if it is right and proper. The instruction recommend like 2S for larger props and 5S or more for helicpoters.
Has anyone set up the braking feature on the Masterspin 99 and tried it?
Hello J Lachowski
I have a Masterspin 99 and C50 13XL Comp and my setiing is:
Acceleration is 1S
Initial Brake 0%
End Brake 10%
Speed brake 0.1S
Timing 0ΒΊ
Curve Exponential
I hope this helps.
Pablo
Acceleration is 1S
Initial Brake 0%
End Brake 10%
Speed brake 0.1S
Timing 0ΒΊ
Curve Exponential
I hope this helps.
Pablo
My Feedback: (46)
NJ
Any particular reason for using the Expo curve over a linear curve? I was told to leave it linear and use the throttle curve on the transmitter.
Hi Joe, yes with expo curve you have a smoother response to acceleration at the start and low throttle which is good for the motor specially if you have a inrunner with reduction
Hi Guy's
Just wondering what is the diff between C50 13XL Comp, and the 14XL, or 15XL? Also what is the optimum speed controller setting and prop combintaions for each of the three motor?
Was always wondering about the difference was, hopefully someone can help.
Thanks for your help,
ORIGINAL: PATTERNPATTERN
Hi Guy's
Hi Guy's
Timing should be set at 0, 1, or 2 degrees. I use linear curve, soft acceleration and slow shutdown.
Hope this helps, Jim
