RE: V24 and Z DRIVE, any experience
Your CG is probably too far aft. When you replace the fuji engine with the zenoah, you need to move the cg forward to account for the added HP. Adding a rcm drive to the rear of the boat will only make the problem worse. JAW can get the RCM drive for you if you want the scale looks of a stern drive, but it will not solve the problem of a poor set up. You are not too far from me if you need some help with the boat.
