RCU Forums - View Single Post - What would it take to hover a Ryobi?
Old 03-04-2003 | 10:19 PM
CrazyHerb-RCU-delete
Default What would it take to hover a Ryobi?
Ok...so the Ryobi will put out what? 12lbs thrust or so?
With CH ignition it's around 3lbs motor weight.Maybe a bigger throat carb?..add radio, batteries, airframe.....can it be done under that weight?
Good question to ask would be....what kind of airframe could a person build Scratch. To get a Ryobi to hover without the airframe rattling itself apart?
What would be the ideal weight of an airframe with servos/battery installed to meet the 1:1 thrust ratio?
Recommended servos? Battery sizes? Max airframe weight?
Has it been done? I'm thinking the new two-ring version might actually be able to??
Just something to think about..... to make a giant scale 3D machine for less than 200 buxs (with engine).
Now THERE you'd have a VERY popular plane.....
Any ideas?
High Flights
CrazyHerb
