RCU Forums - View Single Post - 9CS Throttle Programming Question
Old 06-20-2007 | 03:56 PM
Bax
Default RE: 9CS Throttle Programming Question
You can use an offset mix activated by the same switch as the throttle cut feature to kill both engines, but there isn't a way to emulate the throttle delay feature.
Throttle delay only works directly on the throttle channel, and can't be used with other channels.
