9CS Throttle Programming Question
My Feedback: (47)
AL
I have a twin engine aircraft and am using channel 7 for the second throttle servo.
Is is possible to make throttle delay and throttle cut work on channel seven.
Dan
Dan
You can use an offset mix activated by the same switch as the throttle cut feature to kill both engines, but there isn't a way to emulate the throttle delay feature.
Throttle delay only works directly on the throttle channel, and can't be used with other channels.
