RCU Forums - View Single Post - ASM Comet DH 88
Old 06-22-2007 | 08:30 AM
Eric.Henderson's Avatar
Eric.Henderson
Default RE: ASM Comet DH 88
ORIGINAL: Cyclic_ Hardover
Looks good. The guy gave me a pair of 91fx's for his with pitts plus the retracts. They went in okay. Probably have it finished by the end of the summer
Wow! 91's.
I would consider 61's but the 52 2-c's in it right now haul it very well. They let me do a big loop from level flight.
One thing to consider is prop clearance. My 11 x 6's cut a lot of grass. What prop would you use on the 91 FX's?
Also the plane comes out right on the money as regards the CG with two MAGNUM 52 two cycles. My battery pack is in the rear of the center pod. The only engine upgrade that I would consider would be two 61's.
This plane does fast passes, either way up with authority and climbs out at each end with ease.
Just realised something--Sorry to insert this much P-61 data in DH88 thread.
Regards,
Eric.
