RCU Forums - View Single Post - Rotor head setup
Old 06-22-2007 | 08:48 AM
ksechler
Default Rotor head setup
I have set up my TREX 450SE per the finless videos and I have been flying it for some time. I have noticed that my cyclic is not as crisp or responsive as some of the Trex's you see in the 3D demo videos floating around on the web. I have added the 220mm flybar with no weights, wildman dampers, 325mm carbon blades and am using a Hacker AX20 motor (plenty of headspeed). I have set my cyclic throws so that there is no interference at either extreme of pitch (+- 10 degrees). I am thinking that I could use one of the mixes in my radio to allow more cyclic near center but limit the throw at the pitch extremes. Has anyone tried this, or do you have any insights into my dilema?
