RCU Forums - View Single Post - Senior Telemaster Kit Modifications To Be
Old 06-22-2007 | 04:03 PM
  #44
Rodney
Default RE: Senior Telemaster Kit Modifications To Be
If you are using ailerons, take all the dihedral out of the wing, works best with a perfectly flat wing. Any polydihedral or dihedral will cause the plane to be very poor in the roll axis. However, if not using ailerons, then the dihedral will be necessary.
