RE: Multiplex Magister RTF
Actually I bought the RTF, so it came with the Multiplex Servos, but I installed a second servo for the ailerons almost inmediately, so that each wing has one servo. Now I've replaced them with HS-65 servos, again one for each aileron, but this time I'm using a direct linkage instead of using the control wires (This is when you can notice that English ain't my first language, and I'm so tired that even thinking is hard.). I'll try to take pictures tomorrow and post them, but the main thing is that the HS65 are much smaller, so I could place them near the aileron (About an inch and a half inside the wing, measuring from the aileron inner side) I hinged all control surfaces with Dubro hinges, and the increase in range was fenomenal. (But you have to use Expo, or it looses its trainer capabilities).
Regards,
Javier
