RE: Aftermarket ECUS ???
I think Gaspars FADEC is the nearest you will get to a DIY program yourself ECU. I think they can supply them unlocked so you program things like starter motor voltage, the temp gas turns off and what RPM to turn the starter off. All the things you can't normally get into with most ECU's.
Jason
