RE: AHHHHH
Did you try going back to stock settings? You should be just about flush on the low speed (located on the carb slide) and I think 4 turns out on the high speed from closed. The idle gap is sorta tough to just throw out there, I kinda just learned to eye ball it and been lucky enough I am usually dead on within +/- 1/8 turn. Probably about the thickness of a quarter or so I guess would be a good approximation.
