RE: Problem with LT-40 Build
I ran into similar issues. I left the lower spars, and TE a bit long. I used the TE for spacing the ribs. Once the final rib was in place, I cut the lower spars to length. Then after adding the wing tip piece, I cut the TE and LE.
Remember, you can always cut it shorter, but you can stretch it longer...
