RE: Construction Techniques!?
Thanks guys for your help...
As for the tissue stuff i decided to use it just because i already had some and i glued it first to the leading edge, wrapped it around the wing back the the leading edge then glued it again with a 1" overlap and then after a mist of water i sat it under my lamp to dry - the result fom this somewhat home made attempt...PERFECT. It turned out really good!
