RCU Forums - View Single Post - Aftermarket ECUS ???
Old 06-26-2007 | 03:39 PM
John Casey
Banned
Default RE: Aftermarket ECUS ???
Start and run times.?????..........
ECU data is hardly any indication of the condition of any jet engine good or bad.
It won't tell you that the engine was run through the trees,and crashed
in a COMP arf mig 15 in Delray beach florida, by an englishmen, with witnesses,
and then ponded off to someone. in California... with grass stains
and bent compressor blades...... as newly factory rebuilt and never flown.
heck you can zero time
a jetcat ecu just by holding the menu button down for 1 minute till all the leds all flash together
(at least on the older models) wiping out the run times.
thanks for th input guys...
